- 25 Nov 2011
- The KOP
is there a patch you can download for crysis 1 steam verision for dx11?
No dx11 in crysis 1, dx10 was as far as it went and was very new at the time.
ok thanks does the steam version come with dx10? or do i have to install it my self.
thanks
thanks
If you're running vista or 7, then Crysis 1 starts on DX10 by default.
Put all settings to max. IIRC All settings HIGH is DX9. Settings with Enthusiast is DX10. Dont take my word for it, not had crysis installed for ages![]()
