You're kidding right?
Nope, even the creator of the tool said so I thought?
Edit: Yeah, he did
"Does it actually make a difference?"
"Not really. Hardcore pretty much maxes all of these settings."
It does work, and i get 30 FPS with everything on, and it's still playable despite i've had to turn crossfire off due to screen flickering.
No SLI in crysis 2 . will the patch fix that?
my G15 keyboard shows only one 480 being used in crysis
so i presume they will fix this yes in a patch ?? does anyone else use sli with C2 have any problems?
nvidia have issued an SLI update
http://www.nvidia.com/object/nvidia-multigpu-SLI-profile-update-v7-driver.html
Fixed SLi perfectly for me, I'm using the same cards as you.
