Crysis at 60fps?
10 Aug 2005
Hi there
Has a card been made yet that will run the original crysis with full eye candy at 60fps or over (paired with a q6600@3200)?
Regards
get a 6990 with a dual xeon system @ 4.0ghz on each CPU and run crysis 1 with every visual mods @ 800x600 and im sure you will break 500fps without cpu bottleneck :)
Hi there
Regards
Graphic card alone won't be able to make Crysis constant at 60fps+, unless at ridiculous low res; even overclocked i5/i7/SandyBridge only manage around minimum 40fps at best at 1680 res.
