Crysis-cvars/commands?
Caporegime
1 Jun 2006
Notts
well its for single player.ive tried to ensble godmode but it wont let me anyone no y?also whats best config to get it looking best.game is not patched at moment.
i found this on web but it doesnt work now but did before
"C:\Program Files\Electronic Arts\Crytek\Crysis\Bin32\Crysis.exe" -DEVMODE
i removed it and installed on d partition.yes i renamed to D but it still wont work.
basically just wanna rip through it as fast as possible cause ive tried 3 times already and i wanted just to see whats it like before removing from hd.
Add, g_godMode = 1 to the difficulty file you're playing on.
In here: C:\Program Files\Electronic Arts\Crytek\Crysis\Game\Config. Named diff_easy, diff_normal, etc.
Actually, think I might like to play through the game again with infinite ammo :)
I want to use the Scar, which I hardly ever did due to limited ammo :(
Think will have my thrid play through this weekend :)
Yes, I like the game....
i went to the location but only thing is the game notepad do i add it in there.
it isnt in config though.
just tried adding it there didnt work
why cant you just drop console and put it in there like all other games.
tried adding through console just says unknown command.
