I have tried it 5 times already, i did also reinstall the Demo but every time i hit the water i crash exactly on same screen ! There was some info at nwnews that you are able to fix it by pressing ESC button just before you land in water however I have tried that trick but it didn't work or maybe i done it wrong !
If anyone else is having the same problem or found solution, you share would be appreciated, I am currently trying to find a solution myself but nothing so far !
cheers
vai
cheers
vai
