Crysis demo
17 Aug 2009
Finchley, London
I'm currently downloading a 1.8GB demo of crysis. I want to finally check it out as everyone says this is the benchmark game for testing your rig. What kind of settings and what kind of framerate can I expect with my sig rig? What kind of framerate determines if you have a good rig, at least, on reasonably high settings? And is fraps good enough to check framerate?
With crysis anything over 30fps is playable.
I'd say with your rig you should be able to use Enthusiast settings. And yes fraps is what most people use to check framerates.
Thanks. Ok, been using fraps to check framerate in tomb raider underworld, so I'll use it for crysis. Is enthusiast settings equivalent to medium or fairly high settings, and does this mean I'll see the graphics pretty much as intended or will I be missing out on much detail? I presume 60fps with everything maxed out is what the top ninja rigs achieve ?
Guys, I tried out the demo. Probably overly ambitious, but I set the game res to 1920x1080. Everything was on HIGH, as chosen by the game optimiser, not me. Although the res was set to 1024 before I changed it.
Very smooth, no lag, no jerkiness. However, typing r_displayinfo 1 into the console, it shows pretty low framerate. Standing in one area showed 30fps, but as soon as I started moving it dropped considerably below that, down to 20 and often lower. Considering how good it looks and how smooth (I was expecting a slideshow), it surprised me the framerate isn't higher. So it's very playable right now. Anyway, what would be best to get nearer to 30fps? Take down the res first? Or leave the res and take down some of the settings that are on high? Putting 2 x AA on or leaving it off didn't make a whole lot of difference to framerate.
With your card AA shouldn't really cause much of a drop.
Crysis uses a very could motion blur that really makes low framerates (that's why I said 30) look good.
TV displays at 24fps but because of the natural motion blur from the camera it looks perfectly smooth.
When I played the demo it ran at 15-20fps on my 2900XT but it was still well playable. Though maybe not online. It would probably feel a bit clunky then.
Woah, all of a sudden, I'm now getting much higher framerate between 30 and 40fps, going no lower than about 27fps when it gets busy. Yesterday I was getting 15 to 20fps. :confused: I'm still on 1920x1080 and high settings. No AA.
Yesterday:
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 96.94s, Average FPS: 20.63
Min FPS: 16.56 at frame 1960, Max FPS: 23.74 at frame 989
Average Tri/Sec: -16937024, Tri/Frame: -820950
Recorded/Played Tris ratio: -1.12
!TimeDemo Run 1 Finished.
Play Time: 93.88s, Average FPS: 21.30
Min FPS: 16.56 at frame 1960, Max FPS: 23.99 at frame 1016
Average Tri/Sec: -17246738, Tri/Frame: -809527
Recorded/Played Tris ratio: -1.13
!TimeDemo Run 2 Finished.
Play Time: 93.85s, Average FPS: 21.31
Min FPS: 16.56 at frame 1960, Max FPS: 24.34 at frame 1012
Average Tri/Sec: -17252098, Tri/Frame: -809589
Today:
Play Time: 59.71s, Average FPS: 33.50
Min FPS: 23.88 at frame 1943, Max FPS: 41.78 at frame 926
Average Tri/Sec: -28261136, Tri/Frame: -843683
Recorded/Played Tris ratio: -1.09
Play Time: 55.71s, Average FPS: 35.90
Min FPS: 23.88 at frame 1943, Max FPS: 43.63 at frame 990
Average Tri/Sec: -29875620, Tri/Frame: -832124
Recorded/Played Tris ratio: -1.10
Play Time: 55.44s, Average FPS: 36.08
Average Tri/Sec: -30002822, Tri/Frame: -831628
!TimeDemo Run 3 Finished.
Play Time: 55.49s, Average FPS: 36.04
Average Tri/Sec: -30009468, Tri/Frame: -832560
TimeDemo Play Ended, (4 Runs Performed)
