Crysis help *spoilers*
2 Aug 2004
Buckinghamshire
Hi all. Im playing crysis due to being bored and I believe im at the last boss.
The warship has moved over the carrier and I've blasted open the hatch on it's underside yet can't for the life of me, get the tec cannon to lock onto the warship as instructed.
Tried pointing it every where and reloading from an earlier save point, but with no success. Any ideas? Thanks.
P.s typing on my n95 due to my net being down, so sorry for poor post.
reload the level from start, worked for my mate, he tried countless times to reload from last checkpoint but never worked :( never had any problems with it myself luckily but i suggest you try that and see if that works :)
Sorry to hijack, bu t I'm also having a problem, except its in the bit just before the tanks. I've just blown up the ship, and gone over to the tunnel, that commander guy has said his stuff... now what? I can't get in the tanks, and he doesn't say anything else.
look for the camouflaged whole in the ground....u will know when you are stood on it...it dips about 1 inch then shoot the rocket at your feet.
get your guns ready when u fall.... u may want to shoot someone
