Is there any hidden settings in crysis that lets you enable higher graphics settings then very high ??
Am Playing it at 1920x1200 8xAA/16AF / highest settings..Even with your set up it will still probably run like ****!!!Out of curiousity, what frames do you get now at the rez you play it on?
Thanks for the replys..Am Playing it at 1920x1200 8xAA/16AF / highest settings..
FPS are mainly around 80fps
