Crysis issue with 4870?
13 Dec 2002
Newcastle upon Tyne
Something really odd, ive got no option for 1900x1200 res, but 1900 x 1080 is there but if i select it says video mode is not supported (yes i have a 1900x1200 lcd :p ) its flying in dx10 mode on very high and looks fine but where could the option go?
using the 8.6 hotfix drivers and 1.21 patch
You can add the res you want to the end of the Command Line :-
taken from the TweakGuide.
Command Line
You can implement any console command, as well as a range of custom commands, via the command line. The way to do this is to right-click on your Crysis launch icon, select Properties, and one blank space after the last character in the Target box, add your command with a plus sign in front of it.
so for your res, i guess it would be :-
"C:\Program Files\Electronic Arts\Crytek\Crysis\Bin32\Crysis.exe" +r_width 1900 +r_height 1200
Worth a try i suppose. :)
