Crysis Minimum specs
11 Nov 2006
Wales, Cardiff
Ok so basically my graphics card is under minimum specs, rest of system is above.
Its a n6600 with 128mb memory. The minimum is 6800 with 256mb memory.
Is it possible for me to play crysis, or will i have to save up and fork out on a new graphics card. :(
I think that it will run at all low settings and low resolution. However, the game is completely different when run in that way. The destructible elements will not work. It'd become blocky-Far-Cry-with-aliens.
It runs OK on my X850, dual 3.0 GHz Pentium 4 at a mixture of low and medium settings.
EDIT: And by OK, I mean 30 FPS.
I expect it will run and be playable, but with everything on low. Still worth getting imo, because the Nano Suit is hella fun, and in the future if you get a better PC, youl be shocked by the graphics difference :).
Ok, well i play BF2 at around 30fps so im ok with that.
Sounds a bit lame that i don't get destructible elements. Probably save up as last gen cards are getting pretty cheap.
I wouldn't bother playing it TBH. The graphics will look terrible, and you're going to get so much popup. :( A friend of mine tried playing it on low, and he said he was getting shot at by enemies that hadn't even come into view yet it was that bad.
