- 2 Dec 2008
So I've been playing around with Crysis for a while now and I've come to the conclusion that it's best as Crytek made it!
Well not totally - I am using Rygel's high res textures, and Silent's High Res Foliage (btw if you want to use both, you need to merge the two as otherwise Rygel's (inferior) foliage will be used).
But in terms of custom config's, TODs etc I find having everything on Very High with Crytek's standard TOD is the best. The others are fun to play around with for a while but I keep going back to this config.
I get decent framerates at 1920x1200 with everything on Very High, V-sync on and 16q FSAA, but the more I drop the AA the smoother it gets, but I like having it on 16q anyways.
Couple of questions: what's the difference between 16 and 16q? And does anyone know of any way of playing against bots in multiplayer on this?
