crysis problem help
12 Sep 2005
Norwich, England
ok got demo, spec as you can see is in sig so maybe cant handle settings maxed out i dunno, but screen res is max 1280x1024 19" screen.
now problem is on any settings, maxed out or all the way low when i move mouse up down left or right it hangs and judders across screen, but if you leave mouse and just use wasd to move without looking with mouse no lag judering?
the mouse is a logitech G5, any known issues? um got latest nvidia drivers vista updated, after installing crysis is said missing some sorta vista fix so i got that. all other games work fine, cod2, UT3, quake wars, moha.
so any1 else get this issue?
help please. if i missed anything just say.
thanks
hank
o and its happens in menu screen, option screen and ingame of corse, and if i continuously move mouse it wont screen wont move at all.
so i dunno why.
cuz it didnt make a shortcut i have to go in via programs folder, should i use the 32bit .exe or the 64.exe, im sure 64 as thats what my system is.
updated the nivida drivers and now 64bit crysis wont load the 2 benchmarks or the game, but the 32bit section benchmarks run as does the game and no mouse issue.
what u rekon to that
