Crysis: Relic level
19 Oct 2002
Auckland, New Zealand
Right, so I've just got round to playing Crysis... And I've got to the VTOL extraction point in Relic, killed all the nano-suited KPAs and everyone else... Apart from two red arrows that are well away from my current location. The level won't complete, even though I have restarted the level twice... Do I have to kill *EVERYONE* on the level to complete??
You definitely killed all 4 guys in Nanosuits?
Once they're dead the VTOL lands and you get in and the level ends iirc.
Keep in mind the dudes in the nanosuits don't appear on your map if they're cloaked. I too was about to throw a strop and was about to hit the escape key after hanging around for a get few mins but in the corner of my eye caught a glimpse of the distortion caused by one of their suits.
This happened to me too. I had to start the whole level again and eventually it worked. Very annoying though :(
I've killed 5 in suits, the threat indicator is as normal, i.e. no enemies near... and all is quiet... I might have to have a go at those other kpa on the other side of the map...
i loved that level, i was all stealth under a tree when i noticed another stealth dude crawling right next to me like straight out of predator, then he said "hello?" and i opened up all over him hehe
I had the same problem and had to restart the level and complete it without quicksaving. Quicksaving seemed to cause a lot of scripting errors on my computer at least so could possibly be causing problems for you as well.
Would that include the auto-saving at 'checkpoints'? As all my saves where done through the main menu?
quick saving is just hitting a key to save in a quick save file i guess. i always go to main menu and do a manuel save and i never had any probs in that mission cept getting the last one to show him self.
i had to run about decloaked before the last guy would show him self :p
