Well it may be possibly because your scaling the screen shot down? Whats it like at 1:1?
- Pea0n
i simply use F12 key![]()
interesting. its just you can set the res of a screenshot in the config, so you can make a huge 4000x3000 res picture, which looks great.
F12 does the job fine.
And the screeny you showed doesn't really show any bad AA or AF. Anyway, it's most likely you're noticing the blur effects more in still screenshots.
the exact same but bigger, lol![]()
the amount of pixels in game is a lot more than that of the picture posted. maybe there's a way to take higher res screenshots?
Do you game at 800 x 600?
Ingame screenshot functions always take screenshots in poor quality that i've seen, a helluva lot of em even save them as .png files >.< Fraps too takes poor quality ones.
If you really want them to look their best then just printscreen and paste into paint. More hassle, but more quality.
It's not the format itself that has a bad quality, just the amount of compression the program is using, a full quality jpeg will look the same as any bmp or png.JPEG is quite low quality isn't it?
