crysis sparklies
12 Oct 2008
i ned to know why i'm gettin sparklies whilst playing crysis
they flash everywhere and are quite annoyin,
my card at stock gets them and is at 51degress load.
please help
PS i have 180.48s
easiest test would be to change drivers and see if you can get them to go away. maybe 180.84's?
other than that, could you try to get a screen shot?
This is a common problem for crysis when using DX10 although I've never had it myself. If it was a heat problem is would usually start off fine then build up over time getting worse and worse
