Crysis vs Warhead
Man of Honour
5 Apr 2009
I understand Warhead runs better than Crysis, but i'm guessing the story carries on from Crysis?
Which one should I get?
(I'm not buying both)
I found crysis to be the better story, Warhead is just an expantion/side story so its not that long.
I would go for Crysis, if you like it then get Warhead.
Crysis is longer and better, so i'd probably get it even though it doesn't perform just as well as Warhead.
Crysis runs slightly worse but looks slightly better. Warhead has some better level design but overall I prefer crysis.
I think Crysis is better but the gunplay in Warhead can be more fun. Get Crysis if you are only getting one.
In Crysis you have to headshot people though or they take forever to die :p Which is what angered people a lot about the game.
Preferred Crysis over warhead. Warhead was good but the third person cutscenes really broke the pace and immersion of the game. I also thought the colour palette in warhead was a bit less realistic than crysis.
Crysis should be longer than warhead aswell. But as other have said both can be had for £25 quid.
