Crysis Warhead: Stuck (possible spoilers)
Caporegime
26 Aug 2003
Leafy Cheshire
Hi guys,
Just made it through to the part where you are on the train, and come across a "massive attack" (train is dead, exosuits are attacking you left right and centre). Well, I've killed everything that came to attack (including the two "drop off" alien craft), and now the game is sitting there as if something else should happen.
I've had no "massive attack: completed" pop up on the HUD, and I cannot proceed into the game.
I've reloaded with no luck, "completing" the section again just leaves me at the same point :(
Any ideas, or if you have got past this point, where "should" I be going next?
You killed the big thingies in the sky
Yep
also found a few sheilded aliens in the swamp not attacking me which I had to bump off.
Killed everything hiding around rocks/trees.
Reppyboyo said:
The train should get going soon.
Its likely there is one of the little alien things hidden somewhere.
The train gets going again? Its on fire :confused:
You should kill off 2 waves of the attack then it should tick off the objective and the train well get going again, shouldnt need to get off the train at all.
Don't remember it being on fire when i played it
I was stuck at the train bit. I spent about an hour jumping around like a breast, punching things, shooting things. Up on a ledge there were some hidden aliens, so I took them out with the grenade launcher and bingo. I really had to hunt for them though, and given where they where, I'm glad I had the grenade gun.
same happened to me but i wasn't stuck for an hour. :eek: i would have reloaded before waiting that long. :p
i knew something was out there because there was a very faint noise that they make. turn up the volume and see if you can hear something. :)
Well I've completed it twice, and just shot the &%$£ out of the aliens both times.
If the train is on fire, it looks like you've failed to protect the cargo and it should have triggered the game over event.
You fail.
The train IS in fire, even from the word go, if you don't believe me, go take a look INSIDE the actual engine unit of the train.
It magically starts to work again after you kill the aliens though :confused:
crysis seems buggy like this..
in a few spots i had to re-load old saves to 'trigger' events
in the first one i went to the top deck before getting the massive nuke gun thing, then the game blocked the door and it kept saying "shoot now!" etc
