- 30 Dec 2011
- Essex
Hey guys,
I have installed crysis 1 on the PC to find that the control scheme for a controller is strange I have gone to change it but you can't.
I have found the only way you can do it is through changing the .xml file which I don't know how to do. So I was wondering whether you know a download for one of these files that is identical if not similar to the xbox 360 controller layout.
I know you guys will probably say that using a controller is not the best but I would just like to try it out.
Thanks
Thanks
