Crystal Reports Query..
14 May 2006
Hey,
Hoping that there is someone who has played around with Crystal a fair bit..I've been handed it to create a report and most of it is fine I'm just having issues with one part which I'm sure should be a lot more simple than I am making it!
I am trying to retrieve a number of records from a DB to create an average from. To do this I am retrieving a number of different fields which is fine but I want to limit the number of records retrieved to 100. I've tried using the Group Sort Expert TopN functon but that doesn't work and I've also tried to do a details supression (RecordNumber >= 101) within Section Expert. The detail supression works for visible records but because it is still retrieving all of the records, any formulas that I create are calculating on all of the records, not just the visible ones. Is there some way of doing this? I've tried to create a 'do while' loop in a formula field to only calculate a sum for 100 iterations but that doesn't work either. Is there an easy way around this as I'm tearing my hair out at the minute!
Thanks in advance!
Do you wish to limit the number of records from the database to 100 or are you trying to limit it once you have all the data?
I'd prefer to limit the number of records retrieved from the DB as I don't need to have any more than those 100 records to do the formulas that I want to create!
Where are you getting the data from? Can you limit the record selection in the underlying query?
I don't have crystal installed at home so can't offer much practical assistance.
