CS 1.6 Command Line Settings
29 Jun 2005
Newcastle
Anyone know those no mouse acceleration settings for the command line for 1.6, can't find them anywhere.
Something like -nomouseaccel -something else......etc.
Thanks.
DaveyD said:
There aren't any. You need something like the CPL mouse acceleration registry fix.
urm very faulse comment there are commands, there are also commands to force refresh rate and also resolution that you can pop into the launch options! a lot of the top players are now using the noforce commands myself included!
as for the cpl gui i find it very good, the config is clean and easy to use and offers me better resolution, if you are serious cs player i would get used to it as if you attend lans they will use a gui of some description (most are pretty much the same other than the background), and also the cpl gui forces 32bit so seeing through smoke is harder again this is a must on lan and online league games! (too many people use 16bit these days and it's very obvious when you get smashed through the smoke and you can't see the guy at all!
Yes, here:
-noforcemparms -noforcemaccel -noforcemspd
At least that's what Lethal's CS Guide said..
