CS 1.6 Crouch Problem
25 Oct 2007
Los Angeles
Hi guys, got a weird one - recently got CS1.6 via stream. I normally use standard wasd key format with \ as crouch. However, it dosn't seem to work in CS - what am i doing wrong?
errr wasd ftl. arrows with the keyboard sideways, so your thumb is pointing down back at you. thats the way real pros play.
but back on topic, thats not the default crouch button so have you made sure its set to crouch? if it is and not working could try inputting via the console. years since i played cs properly so forgive me if this is wrong but it would be something like
bind \ "+crouch"
type that in console i think binds it to crouch.
