CS:GO no display when G-Sync on?
15 Aug 2010
N. Ireland
Hi guys,
Just noticed a weird issue with CS:GO and my new monitor XB271HU.
Whenever G-sync is turned on in the NVCP, CS:GO will launch but no display on the screen, as soon as I turn G-Sync off, it launches fine.
I have ran DDU for fresh install of driver as well as verifying Cache on steam.
I also tried L4D2 which uses the same Source engine and same thing happens, tried it on Mirror's Edge which works OK.
Is there a known issue with Source Engine and G-Sync?
Not sure what happened but had to reinstall Windows since installing a new SSD and after the reinstall, it's all working fine now :confused:
