cs:s crashing :( core2duo
17 Oct 2002
I've just been trying to play cs:s, never really got into it before.
The game seems to crash randomly tho :( It seems to loop the sound on crash, so not really sure what is the cause. I tried my Audigy2 soundcard as I thought it might've been the onboard sound that was causing it, but it still crashes even with that :(.
My spec is in my sig. As I've not really played cs:s before I'm not really sure what could be the cause :(
Other games seem ok, quake4, quake3, guild wars, halfilfe2, halflife2 loast coast etc. Also 3DMark 2005 seems to run ok.
The only thing that's crashing out seems to be cs:s. :confused:
Also I'm using the omega ATi drivers, not sure if that could be an issue or not.
I seemed to get that issue if I went a bit made on the card overclock or maybe processor clocking!!
Have you tried default settings maybe?
I have the exact same problem as well. The only way i fixed it was by playing in offline mode. Really really annoying as i've tried changing my graphic and sound drivers as well as reinstalling the game. Still i have no fix for it.
seemed to be my cpu overclock :(
I forgot I set VMCH to Auto :) changed it back to 1.55v and it seems perfectly ok again :rolleyes:
thx for help :)
might try it online tomorrow lol :D
if I can find any good servers
I have the same problem, I think its the ATI cards. The wierd thing is that some nights it will play for a few hours without crashing while other nights it will keep crashing every 10 mins???
Thought it might be an overclock issue :) took mine down a notch or 2 and worked perfectly after that!!
Let us know if online works ok? ;)
I've been messing around online and it seems like a laugh :)
Quite hard to get used to who's on which team tho because of all of the skins. They look very similar. Seem to be a few team kills on there.
Only really been playing de_dust2 tho, seems very easy to get into as the map is easy to learn.
I just need to setup some proper binds for weapon change now. I've seen some cusom skins & sounds, but can you use them on VAC servers? :confused:
