Hi,
I've recently started playing CS:S again, but I'm experiencing quite a lot of crashes, and I can't figure out what's causing this to happen.
Basically I join a server and I can play anywhere between 2 to 10 minutes then it freezes up with a looping sound and I have to press ctrl/alt/delete to get back to my desktop, where I find a message saying hl2.exe has stopped working.
It doesn't happen all the time, but it is pretty frequent.
Also another thing that does happen a lot is when I first join a server, I get this annoying "warning: connection problem" in red writing at the top right hand side of the screen after about 10 seconds of joining a match, but if I disconnect from that server and join another one the game will work fine.
The system I'm using consists of:
i7 920 D0 (i have it o/ced, but I've tried running at stock and the same thing happens)
Gigabyte EX58 UD5
6GB Corsair Dominator
Asus 8800GTX 768MB
I thought it was maybe the graphics drivers that was causing it to happen, but I tried updating to the latest ones and the problem still persists, it actually seems to have gotten worse tbh.
I've tried 195.62 and 196.21's so far, I don't suppose anyone knows of an older set of drivers that I could try instead incase it is a problem with these newer ones?
Thanks in advance
Gigabyte EX58 UD5
Asus 8800GTX 768MB
Thanks in advance
