CS:S Mani help.
11 Jan 2005
Birmingham
ma_cexec_all rate 25000
Now, i type this into console (HLSW, so dont need rcon infront), and it says "Ran Rate 25000"
Goodie,, but when i check ma_rates, its done sweet nothing.
ma_cexec_all rate 25000, cl_updaterate 100, cl_cmdrate 100
Same thing occurs, says its run all three, but nothing actually alters anything.
If I try with rcon infront, it says bad rcon pass.
Very annoying, and I don't want to install more mods that reduce server reg, so only have basic mani stuff, and NEEd to change everyones rates to normal.
Any help?
Add these to your server.cfg:
sv_mincmdrate 100
sv_maxcmdrate 100
That should work.
Those cvars were introduced at the end of November :)
I noticed those in the mani cfg and set them to 60min and 100max, but people still show as having 30/20 1/1 etc...
with the ma_cexec_all i know everyone has the same at a click of a button (used to have it bound to a key)
sv_mincmdrate 100
sv_maxcmdrate 100
That should work.
Indeed that should work.
Ill give my our mani config a check and report back to see if we have anything different but i dont think we do.
