CS:S Performance
4 Feb 2004
Hi guys, i am getting a little annoyed at fps in CS:S, im running an A64 3500+ and an X800XL with 1gb of cas 2.5 ram. On maps like aztec (and especially at spawn points with lots of players) i get a noticeable slowdown. I have been playing with the settings but not sure it makes a big difference.
Some people have mentioned the r_lod command, do any of you guys use this? Or have an autoexec cfg i could have a look at?
Thanks.
i know a good config which increased my fps and made me better at cs :)
Code:
//Casey's Source Config
//Updated 12/18/05
// _Set netcode settings_
// _adjusts hitboxes and netcode settings for optimal registration_
cl_cmdrate 66
cl_updaterate 66
rate 12000
cl_interp 0.01
cl_interpolate 1
cl_lagcomp_errorcheck 1
cl_lagcompensation 1
cl_smooth 1
// _Set graphics settings_
// _adjusts graphics settings to boost framerate_
cl_ejectbrass 0 // _disables shells flying out of guns_
cl_forcepreload 1
cl_phys_props_enable 0 // _disables trash and cans etc_
cl_phys_props_max 0 // _disables trash and cans etc_
cl_radartype 1 // _solid radar_
cl_ragdoll_physics_enable 0 // _disables dead bodies_
cl_show_splashes 0 // _disables splashes when in water_
fps_max 101 // _caps FPS_
mat_bloomscale 0
mat_bumpmap 0 // _disables bumpmapping_
mat_clipz 0 // _lowers water quality_
mat_fastnobump 1 // _faster bump mapping_
mat_fastspecular 1 // _fast specular lighting_
mat_mipmaptextures 1 // _texture quality decreases with distance_
mat_picmip 2 // _lower texture quality--set between 0 and 2_
mat_specular 0 // _disables specular lighting_
mat_trilinear 0 // _disables trilinear filtering_
mat_wateroverlaysize 16 // _lowers water quality_
mat_vsync 0 // _disables vertical synchronization_
mp_decals 50 // _how many bullets etc will be shown_
r_avglight 0 // _disables average lighting_
r_cheapwaterend 1 // _worse water rendering_
r_cheapwaterstart 1 // _worse water rendering_
r_decal_cullsize 2 // _lower texture quality at distance_
r_drawdetailprops 0
r_drawmodeldecals 0 // _disables decals on models_
r_dynamic 0
r_eyes 0 // _removes eyes from player models_
r_lightaverage 0 // _disables average lighting_
r_lightinterp 0
r_lod 3 // _adjusts model quality--set between -5 and 5_
r_occlusion 0 // _disables occlusion--lowers image quality but gains FPS_
r_propsmaxdist 100 // _lower object fading distance_
r_renderoverlayfragment 0
r_rootlod 2 // _lower overall game detail level_
r_shadows 1 // _set to 0 to disable shadows (not recommended)_
r_teeth 0 // _removes teeth from player models_
r_waterforceexpensive 0 // _disables high-quality water_
rope_averagelight 0 // _disables average lighting on ropes_
rope_smooth 0 // _disables antialiasing on ropes_
rope_subdiv 0
rope_wind_dist 0 // _disables wind effects on ropes_
// _Set processing settings_
// _transfers load from GPU to CPU to boost performance_
r_3dnow 1
r_mmx 1
r_sse 1
r_sse2 1
// _Set violence settings_
// _increases blood to help you see hits better_
violence_ablood 1
violence_agibs 1
violence_hblood 1
violence_hgibs 1
// _Other settings_
budget_show_history 0
cl_crosshairalpha 999
cl_crosshairusealpha 1
jpeg_quality 100
sv_forcepreload 1
clear
go to the config folder and save it as newconfig.cfg or something
then in console type "exec newconfig"
