CS :S problems
23 May 2006
Blythe
I find a server then I have no end of problems. I select a team fine, when it comes to buying a wepon this is the point I get kicked from every server for different reasons, the one I remeber(ish)
Do not try to bypass ATC
its like their is something every server I go to doesn't like, like a hack in my game or something but I dont hack.
not too sure what your problem is but you could try deleting your config file. steam will install it again when you load it up.
