CS:S texture/skin mods
^^ do that just search through the expert ones
*out of curiosity can you get high ress map skins?
is there a pack for this like there was for old cs?
there are packs for guns + character skins (the phong shaded characters are very good) but usually there are better versions of each to be found separately, or if you want a different gun o the original.
They are very handy, thanks for the links.
Seems to add an extra something when bits have been modded on the guns etc.
http://www.fpsbanana.com/skins/34623 just got this one, the guys right doesn;t look too great in screen shots but looks awesome in game :)
phong shaded + righ res skins/models for the Ct + T's (players not weapons) default skin/model style
I tried using thses and they came out like they had a film of white over them. Anything I am doing wrong? It made them look like they were made of water. Looked cool but impossible to tell the difference between friend and foe. I have used other skins before which all work fine. Just cant get these to work
Do I have to increase my settings or something?
