CS Source Problem
22 Oct 2006
Isle Of Lewis
Hi Guys, just installed CS on my new laptop earlyer, its a dell vostro 1700, core 2 duo T7250 at 2ghz, 3 gig of ram, and the 8600m GT 256. I am running cs with all settings on high and its running really good, getting 131 average frames in the stress test, however once I enable AA at any level I get textures showing up with pink through them, what is this and is there anyway to fix this, or will I just not be able to use AA?
thanks
If you change the settings then do the stress test again without restarting css you will get this weird pink effect. Change the settings then come right out of the game, even steam to be sure then restart. All should be fine. If that dosent work try new drivers.
