cs:source spectating on lan - show enemy?
17 Oct 2002
Any command to let you see enemy again while dead? We play against bots and being able to offer intel gives some feeling of use to dead players.
you cannot type to active players when you are dead.....if you are using voice then it's possible. there isn't a command a normal player can type but when setting up the server the host can set it so dead players can view anybody.
*EDIT* try mp_forcecamera 0
host would need to use that command
Are you referring to this command?
mp_forcechasecam [value]
"This is to help stop ghosting (giving enemy locations to your alive teammates while dead over ventrilo or teamspeak). 0 disables it (default), 1 locks the player's chasecam onto teammates only (players lose the ability to roam), 2 doesn't like the player move or spectate while dead. They stay near their dead corpse."
