csp-mag pump rpm
21 Jul 2005
my csp-mag dropped to 600rpm this morning, should i start worrying - its been in the loop for a month happily running at 1700ish - hasnt seemed to affect temps tho - so could be just a false reading ?
now its running at 2700 rpm ? (2 hours later)
You're a brave man to be running one at all in my opinion. Their early attempts at breaking into the PC water-cooling market focussed so much on the "breaking" bit they will have to do an awful lot of good things to overcome the negative PR they got.
ok thats scared me a little :eek:
i was only using it, as it seemed the best choice - especially using a fan header with rpm monitoring.
I think thats made my mind up to install the dual core rad after all....
(rebuild the system and get a new pump may as well while im stripping it all down)
thanks for the info!
