- 25 Mar 2004
- Fareham
Hi,
I run a website at work for internal use that is pretty simple really, it's running ASP.NET C#. Currently I am using a single style sheet for styling my elements.
One of the problems I've had is that sometimes I get a bit lost on how best to approach styling my page content, and often wind up having different classes for specific things that could probably be better served by being cleverer with how I define my page elements and subsequently deciding how they should look. I then wind up getting a bit "lost" in my CSS as there is probably way too much CSS considering most of my content is standardised.
Most of my pages are either full page width contents, as I'm generally just displaying data, allowing users to filter the data. Occasionally I split my page down the middle and have a "left side" and a "right side". Often when doing such things I find myself having a separate class in my CSS for .LeftSide and .RightSide, and then of course I have to define things such as .LeftSide h1, and .LeftSide p for my <divs> and subsequent HTML elements.
I would like to re-approach how I've done the CSS and almost start over, but using more sensible CSS that makes updates easier. Can anyone suggest the best approach to this? what works well for you?
At a guess I should really define my basic styling for all heading elements, all page backgrounds, all paragraph fonts/spacing etc, and then when I want an element to look different give it a different class?
