CSS Custom Maps
2 May 2004
I've been trying to get some custom maps working on my CSS LAN server, but they just refuse to download.
I have set the net_maxfilesize to 100 so file size isn't a problem...
It seems there's some kind of download speed limit on the maps so they come across extremely slowly! :(
I did try setting it up using a webserver but when I do that it just says the map is missing all the time, it doesn't even try to download it.
The maps will be downloading on a LAN connection so they should come across nice and quick...
Any ideas please?
Thanks,
Craig.
Is it possible just to transfer all the maps across using an external HDD or flashstick?
Sorry I don't know if there is a command for upload rate in css, as I don't host a server.
waso_dude said:
best bet is to contact the host of the server, they will sort all that :)
It's my own server at home :)
Yeah, I could easily transfer the map files across to the other computers, but I think it'd be a lot easier to just let the client PCs download the maps from the server... especially as I'll probably add maps quite often.
Thanks,
Craig.
