CSS Float and Clear... wth?!
7 Dec 2007
Derbyshire, Tibshelf
Hi, im having quite an annoying problem to what seemed like something easy...
Basically: I have a map
<div class="map"></div>
and inside that map there are (for this example) 2 links with images inside on each row... first way to place next links on another line was to have a clearing div.
<div class="map">
<a href="#"><img></a><a href="#"><img></a><div class="clear"></div>
</div>
Then thought... can do this without one of those... and decided to have the last image on every row, to have a float:left;clear:both;
<div class="map">
<a href="#"><img></a><a class="clearing" href="#"><img></a>
</div>
which seemed to work in a few browsers using the odd hack, but not in every browser.
So I decided to use the PIE method to clearfix:after on the last <a> of each row that would clear:both; after each thing...
Problem: The PIE method... seems to only work using a DIV... and when you apply it to an <a>, clearing doesn't seem to work, but content:"lol" places it inside of the <a> rather than after (probably why you can't clear inside an <a>)
Tried to also do 'overflow: auto' and 'overflow:hidden' on the last <a> but nothing seems to work :'( only the <div class="clear"></div> method works...
Anyone have a clue what the problem is? :/ Thanks s o much
Relooking at the stuff, and I realise that the :after pseudo does work correctly, but shouldn't be used in this case...
same goes for the other thing... I mistakenly thought they were having 2 things next to one another then clearing after the last element. But instead they have an outer div with something inside.
<map>
<a><a><a><a><a><a> (new line)
</map>
is kind of the effect I want... I've tried setting the width so that when it reaches the end, it has to start a new line... guess I could attempt that again :/
er.. what?
You don't need a div to use clear:both.. just set it to a br.
Code:
<style type="text/css">
.float { float:left }
.clear { clear:both}
</style>
<div class="float">&nbsp;</div><br class="clear" /><div class="float">&nbsp;</div>
