CSS Help
3 Jan 2005
Hi all wonder if you can help:
I have placed a bg image on my page and set it to 50% position. this should carry the drop shadow all the way downthe left hand side and it does in IE. However, there seems to be a 1px difference in Firefox - any ideas anyone?
The Ark
Steve.
well having a little play you can alter the following
Code:
#left
 height: 496px;
 width: 161px;
 text-align:left;
 top:40px;
 background: url(images/left.jpg) left no-repeat;
 margin-left: -1px;
#content {
 float: left;
 color: #333;
 border-left: 1px solid #596049;
 border-right: 1px solid #596049;
 margin: 0px 0px 0px -1px;
 width: 388px;
 display: inline;
 background-color:White;
Here i've changed the left margin on the left div and i've changed the left margin on the content div.
This makes it look ok in firefox however I suspect I.E to look odd now so you could implement some i.e. hacks so that the old values are only seen by i.e. based browsers.
I usualy use
* html
for i.e. prowser only and use
*:first-child+html
for i.e. 7 only
Thanks for the reply :)
As you said IE is now off - I can't understand the reason - very frustrating! I'm tryiing to add a hack for IE browsers but am having troublew understanding how to do it - could you be more specific? TIA :)
It depends on the IE versions.
if you wanting to change something on just I.E < 7, you can use.
* html
so for example if its for the left div you would use
* html leftDiv {
Then everything inside that would only apply to IE versions < 7.
The same for IE 7, use
*:first-child+html leftDiv {
Is there a more simple way of getting the left column to go all the way to the bottom of the page? That way I can just put a bg image in #leftcolumn?
I've ended up putting a bg in the #wrapper div and works perfectly in IE! But it doesn't even appear in Firefox?! Anyone know why?
