CSS help
Caporegime
30 Jun 2007
Wales
Anyone else had thier css turn to a brown screen where there basically a bunch of brown triangles leading to the centre of te screen nothing else?
Up-to-date drivers, and up-to-date Css , never seen it before today.
Any help?
I had that for a while - certain guns had what looked like massive swords sticking out of them, and people would often have triangles going from their guns to either their target or a fixed location on the map.
Thought I needed a new card, but was advised on here to just re-seat my card, and they've since gone.
a hax that means i can only see brown triangles?
Did you see this when you where hacking aron? ;)
no it's not anything like that the whole screen just turns to brown triangles leading to the middle, I'll try and get a SS
every time i try and gett an SS of it it comes up either blank or doesn't recognise it's happened :/
i've had it, spikes coming off the guns (which was helpful cus it would sometimes follow players and give you easy kills :D) and graphical anomalies (can't think of what it called but that will do) was due to my GPU overheating. try re-seating it as above, cleaning it, checking the temps etc
Colour correction enabled ? - Though I appreciate that's a long shot.
Is your card overclocked ? If so reset it.
Try a previous driver.
Sounds like your card is running too hot, like my previous two cards did. If you have manual fan control available then turn it up.
