CSS layout help for noob
22 Dec 2004
Southampton, UK
Hey,
I need a bit of help please, I have taken a template that was produced using tables and i'm trying to recreate a similar version of said template using CSS layout and teaching myself as i go along. (I have only ever used CSS for text prior to this, and i'm reading W3C schools tutorials as i go)
The template is below and i've circled the parts i need help with:
Firstly, the left and right side bars which fade from gray to white the image used is 16px X 17px I have only managed to get this to appear in the top left corner of the blue logo section - How can i do this?
Secondly, How can get the pictures and icons into CSS layout?
Thirdly, i'd like the footer to be at the bottom of the window with the main, news & gallery sections expanding down to fill the space.
What i have done so far is here: CSS Layout
feel free to add me to MSN to help me!
Thanks for all help in advance
Try something like:
Code:
<div id="outer">
  <div id="leftShadow">
  </div>
  <div id="wrap">
    <!-- all content here -->
  </div>
  <div id="rightShadow">
  </div>
</div>
LazyManc said:
Try something like:
Code:
<div id="outer">
  </div>
  <div id="wrap">
  </div>
  </div>
</div>
that didn't work
All the code can be seen by viewing the source - didn't think there was much point in posting it all in here
Well i've managed to get the images where i want them and the text looking right. Thanks to conrad11 for some pointers
Here's what it looks like now : CSS layout pictures
I'm still stick on the left & right side bars, any ideas?
And also now the gallery section on the bottom right, i want to extend the border on the left so it goes right down to the footer. here's the code
Code:
#gallery {
	background-color: #AFC0D0;
	float:right;
	width: 248px;
	border-left-style: dotted;
	border-left-width: thin;
	border-left-color: #FFFFFF;
	height: 100%;
Harib0 said:
that didn't work
I haven't given you all the code there obviously, you'll need to place the shadows as background images using css.
Basically you want to split the page into 3 columns, with the middle column holding all your current content and the side columns are holding just the shadow images. You could do it all with 1 column and a background image but then you would have to re-create the image if you ever change the width of your site.
"Faux Columns" doesn't apply in this case because that particular technique is for making un-equal height columns look the same height on the page. What you have is 3 equal height columns, so there is no need to use it.
One way to do it is to set the columns as a background for the body and simply repeat them. I think alistapart uses that as part of their faux columns article, actually :)
Yeah I think that is what I meant originally, although I have done it using LazyManc's method in that template.
EDIT:
Can you actually have two background pictures with different positions on the body, or were you referring to having one image and repeating (as that is what I was trying to suggest in my first reply)
That's what I meant :)
Simply creating the shadow image which is the width of the content with the shadows on each side, then centering and repeating it.
Something like this probably...
Code:
body{
background: url(foo.gif) repeat-x top center;
Code:
body{
Yeah, thats what I meant here:
but it has limitations, as mentioned.
I'm still really stuck on this one guys, Conrad kindly did me a template, but when i put my content into it the greay side fades diassapear. Within my own site i have managed to get the graphics to appear top left and top right but only when i put some text in them, can't get it to appear without the text or to repeat.
tell me what you need - as this is my first go at CSS layout
