- 20 Oct 2005
Hi,
I've been tasked with throwing together some online case studies for work over the next couple of days. I studied basic HTML at college many years ago, and am competant with tables for layout purposes, but no nothing of CSS so I would like to use the opportunity to delve into some learning
I'm aware of w3schools, and am sat here with a nice book, but time is of the essence so would appreciate some direction on this.
It requires a formal presentation style so the layout I'm mocking up in Photoshop has a subtle beige BG colour with a centered white area, 4 tabs across the top (like the tabs in Google Chrome) that just go to each of the 4 case studies. This all has a subtle drop shadow to imitate a paper document. At the top of the document is the company logo and the bottom has a watermark.
The actual document itself, between the logos, just needs a heading, a simple 4 x 3 table for specifications and below this is a large image with 3-5 thumbnails below this that, when clicked, change the large image.
Now, I can slice this up in Photoshop and generate the CSS from PS itself, but it specifies everything as 'absolute' positioning, and being that each table and image will vary in size, I'm not sure this is the correct way to go about things.
Essentially the sides of the document should stretch to accomodate the size of the content.
Any pointers or directly relating tutorials out there?
Thank you
Thank you
