CSS Layout Help:
31 May 2005
Alfreton,Derbyshire
I'm thinking of the best way to split this up into Div's using css for the layout.
http://mattwaddy.com/images/mock.jpg
The header / nav area and the footer are fine, should I use a three column layout (liquid) for the main content? I seem to have an issue with content falling down when trying to use percentages.
Any advice? What would be the best way to split it up?
From the pic it looks like they'll just be a flash gallery in the middle. Why would you need 3 columns for that?
It's not going to be flash. I'm hoping to have small navigation options toward the left side, the right will be used for the various galleries, a step earlier.
