css quicky
6 Feb 2004
England
all i want to do is position the delete buttons so they'll be at the same level at the bottom of the bordered div regardless of how big the thumbnail is.
the only css i'm using so far is for the div....
Code:
.thumbnail {
float: left;
width: 220px;
height: 375px;
margin: 0 15px 15px 0;
padding: 5px;
background-color: #363636;
border: solid 2px #FFBD32;
color: #FFBD32;
thanks for any help. :)
Jaffa_Cake said:
Code:
vertical-align: bottom;
What he said.
I haven't checked it works myself, but i am 99% sure it will.
Failing that, have a <p> tag for the image and set a height....the button will then appear in the same place.
the vertical align didn't work. i don't know why? this is why i hate css. it never does what you expect. :D
but the <p> height thing worked a treat. thanks both for the replies. :)
It works for me, arrghh! :eek:
well i am a complete noob (is that 1 'o' or 2 :p) and i might have done it wrong? i don't know. this was the code....
Code:
<div class="thumbnail" align="center">
//textarea & thumbnail code. no divs...
<form....>
<input class="delete"  type="submit" name="delete" value="delete" />
</form>
</div>
Code:
.thumbnail {
float: left;
width: 220px;
height: 375px;
padding: 5px;
color: #FFBD32;
input.delete {
that's right isn't it?
hehe. still no joy. :o
whilst on the subject of css, does anybody know any hacks for styling a file upload box. i found this page
http://www.quirksmode.org/dom/inputfile.html
which says it's pretty much impossible. it does contain a workaround though and yet again i can't interpret other people's css to work for me. ideally i'd like to style my browse button if possible. :)
this might sound complicated, but you should understand if you know enough CSS. There's probably an easier solution but this is what i might have done if i didn't play around with it long enough.
Put all the content of the right box in a DIV with a fix height - which is in the table/div (depending on what you did - with the border), excluding the delete button, put the delete button in a div and give it a margin-top property. This would work... assuming your form titles, form fields and your maximum thumbnail height is the same.
i don't know any hence my original post. :D i like how easy it is customise the appearance but layout confuses the hell out of me.
yup, craig posted it above. i've already mentioned it works fine putting the image inside a <p> of a fixed height. :)
and there is no "right" box. :confused: i'm using the same code inside a loop to display each one. i only showed 2 in my opening post to illustrate the point about the buttons. :)
hehe, we're going round in circles here. how is that simpler than
Code:
<p style="height: 200px"><img src="" /></p>
<input type="submit".....
and nothing in the external css file? :)
Code:
It depends what you are used to. I try to avoid all the positioning properties in CSS, but some people love it use them, so you just have to learn both if you want to be able to read other peoples code.
....oh and my name is not Craig btw ;)
EDIT:
All the technique is doing in the link you gave is putting an overlay over the file input and using javascript to copy over the text from the file input to the overlay box.
To be honest, I wouldn't bother.
Code:
But is that valid?
oops. sorry. i got you mixed up with craig321... :o
and i've also given up on the file dialog thing. it doesn't look too bad as it is. :)
toosepin said:
But is that valid?
and yes it's valid, why wouldn't it be? it's still css, just inline. :)
Have you tested display on different resolutions inc wide screen? Should always do that when using fixed sizes.
yup. :p
yes i know it's bland. i haven't a single ounce of creativity. :D
marc2003 said:
yup. :p
I think it looks quite good :) Would be better if you added a nice header and some outlines with some nice colour contrasts :)
