css rates?
most servers prefer your interp to stay at 0.10, that script seems to lower the interp gradually depending which setting you use
if theyre saying your rates are dodgy they must be causing packet loss or choke wich makes you harder to shoot as you jerk around like mad ?
Just do it manually to be honest. Safer than using 3rd party software to do it. You should be able to set them to 20000, 85, 85 if you are on 1MB connection or higher and have few problems. Those are the only 3 rate settings that should need to be changed unless you are playing at a very competitive level in which case there are a few other tweaks that can be added.
