css skins
22 Jan 2006
ok, ive skinned my css into next week and back, and it sucks i dont like it :D
as skinning involved replacing files, is there an easy way i can revert them back as i cbfa to reinstall and spend about 3hours for the updates :confused:
unless one of u nice peeps wants to zip your materials/sounds/models folders and msn me them :D :D :D
[email protected]
The way CS:S and other Steam games work doesn't mean any important files will be lost, as the game looks for a file in the custom folder, and if there is not a file, it'll just use the default model/sound/skin from the game cache.
All you need to do is remove the skins / sounds / models folders from your CS:S folder and start CS:S, it should all go back to normal.
