20 Feb 2007 at 22:46 #1 Booner! Booner! Soldato Joined 29 Sep 2005 Posts 9,128 What is going on, i join any game and everything in slow motion and then i get kicked for high ping???? never had this before (2-3 years), what could it be?
20 Feb 2007 at 22:50 #2 Dark_Angel Dark_Angel Soldato Joined 12 May 2005 Posts 12,631 A problem with your ISP perhaps? Try to create your own game, and see if it does it then.
20 Feb 2007 at 22:53 #3 Booner! Booner! Soldato OP Joined 29 Sep 2005 Posts 9,128 ARGH even the menu's are doing it now?!?! like fading really slowly just played CoH for 4 hours, no pings issues, its the source engine!
20 Feb 2007 at 22:56 #4 Dark_Angel Dark_Angel Soldato Joined 12 May 2005 Posts 12,631 Does it happen with all Source games? like for example HL2? You could check that all the files are correct, and none are corrupt. Try verifying the games Cache.
20 Feb 2007 at 23:05 #5 Booner! Booner! Soldato OP Joined 29 Sep 2005 Posts 9,128 Ok now this is wierd, my custom toolbars on my botom task bar are going slow too?? Nothing else affected yet, what the hell is this?? need new drivers? (spec in sig!)
20 Feb 2007 at 23:20 #6 alphaomega16 alphaomega16 Associate Joined 4 Jul 2006 Posts 2,357 Did you try a computer restart ?
21 Feb 2007 at 12:08 #7 Begbie Begbie Caporegime Joined 20 Oct 2004 Posts 27,092 Location .... try re-install?
21 Feb 2007 at 12:10 #8 Beenom Beenom Associate Joined 10 Jan 2006 Posts 992 Location W. London Are you using the stardock Object Dock application by any chance?
21 Feb 2007 at 12:37 #9 basmic basmic Permabanned Joined 10 Apr 2004 Posts 13,122 Location Darlington, County Durham Is your graphic card and/or CPU overheating?
