- 24 Oct 2005
Simple. Ctrl + Alt + Del doesn't d oanything. Why not, and what can I do? If you need more info, please tell me what you need.
Not entirely likely to help if running task manager by Ctrl Alt Del, Ctrl Shift Esc, right clicking the taskbar and running it via command prompt doesn't work, is it?Wilf said:Have you tried another keyboard?
Phan7omEli7e™ said:I'll scan using avasy in just a few minutes.
And Right clicking and hitting Task Manager and Run taskmgr doesnt work. BUT, the RUn one, says it is being used by another program.
csmager said:Not entirely likely to help if running task manager by Ctrl Alt Del, Ctrl Shift Esc, right clicking the taskbar and running it via command prompt doesn't work, is it?
Wilf said:Alright smarty pants, I missed the post where he tried that.
