- 11 Oct 2011
hi guys
just wondered if any OC people can recommend a cube case that my mobo will fit into. ive checked a few cases but not all specify the max size of the micro atx board.
my mobo is : Gigabyte GA-H97M-D3H Socket 1150
dimensions: Micro ATX Form Factor; 24.4cm x 22.5cm
I was looking at this cheap and chearful case:
https://www.overclockers.co.uk/kolink-satellite-micro-atx-cube-case-black-ca-005-kk.html
but it says max mobo dimensions are:
Motherboard Support: Micro-ATX (Up to 22.6cm x 18cm)
which is smaller than the gigabyte board i have
any advice?
cheers
any advice?
cheers
