Cube Gear shifter screwed, need help
Man of Honour
17 Nov 2003
Southampton, UK
Normally, I'm quite capable sorting this sort of thing myself, but I think I need help here. I have this bike:
https://www.thebikelist.co.uk/cube/ltd-29-2014#
The left hand shifter for the chainset is completely borked and needs to be replaced. I may as well replace the cable while I'm at it. Can anyone tell me what I need to buy and maybe send me some links to get it?
Any help gratefully received.
Looks like your current one is: Shimano SLX M7000 2/3-Speed Front Shifter Clamp with Front Display.
Do you actually use 3 at the front? If not you could just go 1x10.
Yeah, I do use all three at the front. Would you be able to suggest any links? It feels like a bit of a mine field.
Ah that's no fixable then :o
Shimano lists the newer M6000 and M7000 as compatible with older M610 front derailleurs.
Your shifter will have a part number on it if you are trying to source like for like will be SL-M660/670.
You can look back at archive charts here too.
https://productinfo.shimano.com/#/com?cid=C-432&acid=C-441
https://www.tredz.co.uk/.Shimano-SL...ARtZlK2HavsewWvuQQO3H1mvgRZ326jBoCq38QAvD_BwE
I've gone for your link plus a new cable. Thank you very much for your help, I'm not sure if have got there on my own :)
