Cube Mountain Bike Question
24 Sep 2007
Hi Guys
I'm thinking of buying a Cube mountain bike. I've noticed that it has one cable that's routed internally. Does this make maintenance a headache?
Thanks
Not really. It should help keep muck out of the cable so it should need less maintenance.
It makes things more difficult for replacing the cable. If you pull the old one straight out, it can be a pain to get the new one threaded through. You just need to tape the new one to the end of the old one before you pull it out and you'll be fine.
