Hey all, I have a couple of GTX 780s and a monitor that can do 4k (I still often play in 1440 though) and I've noticed that the top card often runs 10C or more hotter than the bottom. I also like things to be as quiet as possible. If I could have all the money for my parts back I might have done something different but I have to work with what I've got. My build is about value for money and balance, I have to watch my budget.
So here is my idea, what if I get 2 of these NZXT KRAKEN G10 GPU Cooling Adapter and a couple of Corsair Hydro H55 Quiet Liquid CPU Cooler, or more likely one to go with the H55 I already have then get a H80i for my CPU.
Alternatively, how about a couple of Arctic Accelero Hybrid II?
Questions/considerations, I'd prefer to keep it below £150, I'd rather use the top exhaust ports but I will use the top 2 intakes on the front as exhausts if it wont reach. I have a spare 4 pin power on chassis fan 1 for the pumps but I would need a 2-way splitter, the rad fans would be controlled by my fan controller. Does my Gigabyte GTX 780 GHz edition have a reference layout? Will the 320w cooling capacity of the Arctic Accelero (or any other given cooler) actually be worse than the 450w Windforce cooler?
Any comments or suggestions as to possible alternatives please. I've love to do it all again with a custom water cooling loop but I think it's out of my price range.
Full system specs:
asrock 990fx extreme3
AMD FX(tm)-6300 Six-Core Processor OCed to 4.2GHz
8gb dual channel DDR3 1600Mhz
Corsair h55 cooler
128gb Samsung 840 Pro
2x Seagate 1TB Hybrid Internal Solid State Drive in RAID 0
Windows 7 Home Premium 64bit
2x Gigabyte GTX 780 GHz edition GPUs in SLI (same BIOS, rev etc despite differences with decal and heat pipes, odd!)
Superflower leadex 750w Gold
Inateck PCI-E to USB 3.0 2-Port PCI Express Card (for the USB 3 front panel as the mobo didn't have a USB 3 header)
Asus PB287Q 28" 4K 60Hz 1MS monitor
Photo:
Thanks!
Full system specs:
Corsair h55 cooler
Photo:
Thanks!
