Curious loss of fps
27 Oct 2005
So i changed my 1440p monitor for 3x 1080p (play a lot of flight sims), however
one of the monitors is doa so I only have one connected atm via HDMI
Now on world of tanks I used to get 80-90fps with my settings at 1440p, but now I only get 50-55 at 1080p but the same settings AA etc.. same with GTA4, used to get 90ish now only 55
The only thing that has changed is that I am using a HDMI cable isntead of the DVI-D, could that really cause such a loss? (I don't have another DVI cable atm to test)
Maybe more CPU limited at a lower res given yours cards aren't working as hard at 1080p and you've got tri-fire 290x.
Vsync is off, cpu use hovers around 30% one core, the rest 0-5%, the GPU usage hovers around 27-30%
vram use is only 1.1gb, system ram 2.9gb, pagefile 2.9gb.
If i turn vsync on it sticks to 60fps, if i turn it off it doesnt go higher :/
Odd, i checked Nvidia control panel and told it to force vsync off, no change.
I updated this Geforce experience thingy to the latest and now its fine 120fps+
\o/
