Surely 5ghz on these chips is possible watercooled? what you think are my chances gettin it stable with this lot
YOUR BASKET
1 x Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - Retail £263.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £154.99
1 x Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £144.98
1 x Antec Kúhler H2O 920 High Performance Liquid CPU Cooler (LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+) £79.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £43.99
1 x Cooler Master GX 450W '80 Plus' Power Supply £26.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £15.98
Total : £744.42 (includes shipping : £11.25).
If you really want higher clocks then i'd recommend waiting for ivy bridge to come out.
A couple of things come to mind. Maybe get a more powerful PSU, so it futureproofs your system more. Also, I hear the Sandybridge do overclock well on air/kind of watercooled, like your choice, so it may be possible to get 5ghz. Just bear in mind you are only guaranteed to get the standard speed, anything else is a bonus really. If you don't get 5ghz you will get close I am sure and I doubt 4.6ghz compared to 5.ghz is much different in the real world.
Is there a lot of difference between the "kind of watercooled" and the full watercooling systems?
We would all like 5.0ghz stable, but you'll probably have to settle for 4.6-4.8.
http://forums.overclockers.co.uk/showthread.php?t=18335424&highlight=startername_Gibbo
This thread is from around the time the i7 2700K were released, plenty managing 5GHZ with less Vcore than other Sandybridge CPU's
the word is out they are all first batch silicon
I could get that with an i5 2500K, though no hyperthreading
My 2700K (one from the first batch that ocuk had) does 5.0 GHz at 1.45V IBT stable (on maximum setting). With air cooling, my maximum without temps in the high 70s was 4.8 GHz, 1.38V). I run a daily overclock of 5.1 GHz at 1.5V (I use chilled water to cool the system, and my maximum temp when folding 24/7 is 54C). That maximum I got for benchmarking was 5.5 GHz (55 x 100). Although I could alter the bclk at low speeds, with high multipliers the bclk can't be altered (at least, I have not managed yet - I might try with my GPU at stock and not folding, and the chiller set to 3C, so I can get maximum cooling for my loop, and see if I can get 5.6 GHz stable on more than one core).
Obviously thing do change between batches, and even between different chips off the same wafer, but I would expect most 2700K to do 5.0 GHz stable if you can keep it cool enough.
